Hum....Help Me Find An Adapter For RCA WG-289
Discussion in 'The Projects Forum' started by Mckayman, Sep 18, 2009.
  1. Mckayman
    Thread Starter Active Member
    Jun 22, 2009
    50
    Well I was able to get my hands on one of these today. I plan on using it for checking the high voltage power supplies on the oscilloscopes I am restoring. I am looking for an adapter so I can connect the WG-289 to a modern multi-meter (with selectable range of course). The multi-meters have general banana plug inputs on them.
    What I had in mind so far was connecting large mic coax "this is what I think it is right now" MALE to MALE > Female large mic coax to BNC > BNC to Banana plugs.
    Anyone have any better ideas? Or will this even work?
  2. JoeJester
    Apr 26, 2005
    3,393
    1,211
    I remember using that probe with an RCA VTVM ... close to 40 years ago.
  3. Mckayman
    Jun 22, 2009
    50
    Yeah a VTVM would be ideal. Unfortunately, for majority of VTVMs that are around that I could use, time has gotten to the best of them. This probe however was somehow spared.
  4. rjenkins
    Nov 6, 2005
    1,015
    69
  5. KMoffett
    Dec 19, 2007
    2,584
    234
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I actually have one of those probes, but not the instruction sheet.
    We used to use them to test the high voltage on the radar transmitters' power supply.
    Inspect the red insulator very carefully using a magnifying glass and plenty of light. If there are any cracks, it's not usable. Finger oils on the resistor are a bad thing; it will attract dust/dirt, and eventually start carbon tracking, resulting in a flashover.
    Had a tech try to use one of those probes that had an insulator with a hairline crack. It flashed over to his hand, and he did a back-flip into a trash can that was behind him. Fortunately, he wasn't injured - so we laughed at him.
    I haven't used the probe I have, for one because I haven't needed it yet, and also because I haven't been able to find a suitable connector.
  7. Mckayman
    Jun 22, 2009
    50
    Geeze those are expensive adapters. :rolleyes: Haha, I maybe better off fixing up one of the VTVM RCA [SIZE=-2]WV98Cs that are around and have a solid direct connection and avoid the adapters in the first place. :p[/SIZE]
    The probe appears to be extremely solid. Wires are not brittle at all, and the red plastic insulator is still well together. This probe was still in the original tissue paper when I first opened the box. I don't think it was ever used... For the resistor. It is still extremely shinny, and appears to be very clean on both ends. I used a cloth to handle it so my finger oils would not touch it. :)
  8. rjenkins
    Nov 6, 2005
    1,015
    69
    I didn't say it was a PL259, I asked if it was the same thread - some mike fittings use that exact same thread, meaning an SO239 could be adapted to work & that is a common, cheap connector.
  9. KMoffett
    Dec 19, 2007
    2,584
    234
  10. KMoffett
    Dec 19, 2007
    2,584
    234
    Sorry. The mike connector is smaller than the old UHF connectors.
    ken
  11. Mckayman
    Jun 22, 2009
    50
    Yeah i'm probably best off just cutting it and retro fitting it.
  12. Mckayman
    Jun 22, 2009
    50
    UPDATE: Well I was thinking about it and I don't want to clip off the old mic connection on this prob. For it being in mint condition, I don't want to destroy that. So I decided just to grab a VTVM RCA WV-98A and get it working and use that. The one I got is in alright condition (battery leaked in it and covered almost everything in nasty stuff) but I cleaned most of that off. However when I cleaned up and got it going I couldn't seem so get a reading on anything. The controls did seem to respond but the needle was just kinda hay wire (wouldn't zero on some off the lower ranges on the DC+ function and vise verse for everything else). The electrolytic cap looks like it might have been replaced not too too long ago. It is newer looking than all the other. But everything else seems to be original. I'm guessing I should just replace the other caps too? Also there was a 5726 tube in the slot were a 6AL5 should have been. I know a 5726 can be a sub sometimes for a 6AL5 but it is alright in a VTVM? I tried different 12AU7s to see if the original was bad but the others preformed the same. Anyone have any helpful hints for me?
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The alkaline material released tends to be pretty corrosive. Get all of that stuff off, and look at it under a magnifying glass to see if parts and/or traces are eaten through.
    All electrolytics will likely need replacing.
    The 5726 should be identical to a 6AL5W.
    http://www.radiomuseum.org/tubes/tube_5726.html
    The 6AL5 is similar to a 6AL5W.
    http://www.radiomuseum.org/tubes/tube_6al5.html
    Did you try using some contact cleaner?
    Look for components, traces, and wiring that got eaten by the leaked battery.
  14. Mckayman
    Jun 22, 2009
    50
    Alright thanks i'll see what I can do.
  15. Mckayman
    Jun 22, 2009
    50
    Okay tomorrow I am going to go to the electronics store to by some caps. I have a question though on regarding some of the tests results from the caps that I tested in the VTVM. On some of the test caps that were listed as .1 \muf at 1000v gave me a reading of .375 \muf. Another was rated as .01 \muf at 400v gave me a reading of .09 \muf. Does this mean that they are bad?
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
  17. Mckayman
    Jun 22, 2009
    50
    Thanks for the tip. What about the caps though? :p
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    What?!? You want a large omega as well as a small one!
