HTL to TTL conversion..
Discussion in 'General Electronics Chat' started by kunalpowar1203, Mar 8, 2012.
  1. kunalpowar1203
    Feb 26, 2012
    7
    i have to reduce a 0 to 24v HTL based square wave signal whose frequency is upto 30kHz max, to TTL ( 0 to 5v) signal. suggest appropriate method for the same.:confused::)
    Also i need to design a block which does the exact reverse.
  2. buzaiandras
    Member
    Jul 18, 2011
    54
    For the first part maybe you could use a resistive divider.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    For the conversion of TTL to the "HTL" you could use the SN7407 open collector buffers.
    With a resistor from each output to the 24 Volts, you will have your 'HTL" signals.
    A resistor of 4K7 will probably work.
    I have attached the datasheet of this SN7407 for you.
    Bertus
  4. crutschow
    Mar 14, 2008
    13,515
    3,386
    What is the current capability of the HTL signal and what is the load of the TTL signal?
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    LM393 Dual or LM339 Quad Comparator for HTL to TTL conversion. Outputs are Open Collector and will sink several tens of milliamps.
    For the reverse direction I recommend a high side or a low side switching transistor. Depends if your load needs to be grounded or can be floating in the off state.
  6. kunalpowar1203
    Feb 26, 2012
    7
    Basically, the HTL signals that i need to convert to ttl are derived from a Rotary incremental encoder. i need to process this signal in a micro controller. and after that. i've to send a copy of the same signal to a motor drive. before i do that, the TTL needs to be converted bak to HTL levels.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    Will the two level converters be at different locations, or can they be together?
  8. crutschow
    Mar 14, 2008
    13,515
    3,386
    If it's a slow speed signal from a rotary encoder then I think a resistive divider (say 25kΩ and 5kΩ) would work to go from HTL to TTL levels (if going to a CMOS input), and a SN7407 to go back to HTL levels, as bertus suggested.
  9. kunalpowar1203
    Feb 26, 2012
    7
    yeah they need to be separate..
