hspice optimize
Discussion in 'Homework Help' started by bbcannon, Dec 2, 2005.
  1. bbcannon
    Dec 2, 2005
    I'm trying to use optimize to get the length of line-line coupling required to cause a 500mV glitch on the output of an inverter load.
    My control file:
    * optimized parameter, start,low,high
    .PARAM prc_length=OPTsl(200,1,100000) $ prc_length is the parameter for coupling length
    [!netlist] $ inv drivers, rc network, inv load
    * victim waveform
    VAS AS 0 GND
    * aggressor waveforms, one aggressor on each side of the victim
    .param tra=1n
    .param tfa=1n
    .param pwa=10n
    .param dutyca=20
    .param ppa='100/dutyca*(pwa + (tra + tfa)/2)'
    VAU AU 0 PU(GND VCC '2*pwa' tra tfa pwa ppa)
    VAD AD 0 PU(GND VCC '2*pwa' tra tfa pwa ppa)
    .measure tran sl FIND par('prc_length') WHEN v(BS)=400mV RISE=1 td=1n
    .model prc_length opt
    .TRAN 0.2ns 100ns sweep optimize=OPTsl results=sl model=prc_length
    .INC "model.env" $ mos models
    Unfortunately, this give the following output, leaving prc_length at the initial condition:
    optimization completed
    relin, relout, grad tolerances not met
    measure failures may have occurred, check limits
    termination condition:
    the maximum number of iterations ( 20)was
    exceeded. however, results might be accurate.
    **** optimized parameters optsl
    * %norm-sen %change
    .param prc_length = 200.2000 $ 0. 0.
    I haven't ever used the optimize command before. Any pointers would be great.
    Brady Cannon
  2. n9352527
    Oct 14, 2005
    Please post your .option line. It looks like you need a tighter convergence, if you haven't already set them. Optimisation generally requires this. I would start by setting relv to 1e-4 and relvar to 1e-2 first. If that doesn't work maybe tweaking the other rel* parameters.
  3. bbcannon
    Dec 2, 2005
    I found I hadn't hooked up the supplies, so the inverters weren't switching. Seems better now [:).
    Thanks for the tips...
