hp33120A function generator
and1_hotsauce
Joined Apr 6, 2011
19
Has anyone used this fucntion generator before?
please note: IM USING MULTISIM HP 33120A
I;m trying to set the function generator to high z, however, at SYS MENU it goes into commands then says 1: COMMA
The manual says it suppose to say 1: OUT TERM
This is the procedure followed:
Press .Menu On. (Shift . Enter). You should see .A: MOD MENU. on the
display.​
Press the .right arrow. key three times. You should see .D: SYS MENU. on​
the display.​
Press the .down arrow. key once. You should see .1: OUT TERM. on the​
display. This means .output termination., which is your load resistance.​
Press the .down arrow. key again. You should see .50 OHM. on the display.​
Press the .right arrow. key. You should see .HIGH Z. on the display.​
Press .Enter.. The instrument is now set for correct operation with highimpedance
loads.​
