problem ,... the power supply volts needle gage is very slow returning to 0 volt after turning off.
I think part of the problem is that i had two supplies connected in series with diodes and one of the diodes fell off the output terminals. Thats when I noticed
the slow return to 0 volts of the volt meter. When I set the volts to like 35v and then turn off supply, the needle will take a long time 3 min to return to 0 volts
In addition, after turning off supply the ne
