HOWTO test the overvoltage protection of a power supply
Discussion in 'General Electronics Chat' started by grieche81, Nov 23, 2011.
  1. grieche81
    Sep 2, 2011
    10
    Hallo,
    how can I test the overvoltage protection of a power supply? What kind of instrumentation do I need?
    Thank you in advance!!!
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Are we talking about input voltage protection or output protection. Also is this a comercial power or a non comercial.
    If you are going to test the input protection. I think a hipot test must be what you are looking for. Look it up with Google (hipot test) and see if it fits your needs
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    hipot test is different from an overvoltage test. A hipot test typically tests basic and functional insulation to ensure isolation between current carrying conductors and the chassis/enclosure ground. Hipot is typically required as a production line test (done on every unit you produce during manufacturing before it leaves your facility)
    I'm assuming you are designing this power supply and not just testing someone elses.. If so your power supply is typically required to meet certain UL (IEC,EN,etc...) standards. Those standards include the procedure or the requirements that need to be met for over voltage protection. All you "might" need is a power supply capable of the required level of voltage. Read the applicable standards.
  4. crutschow
    Mar 14, 2008
    13,479
    3,367
    If you are talking about the output OV crowbar protection setting of some commercial bench supplies then you just need a voltmeter to determine the point at which the OV trips as you increase the output voltage.
  5. JMac3108
    Aug 16, 2010
    349
    66
    I assume this is a power supply you designed or are modifying or working on, and that you fully understand its operation. To test the output overvoltage protection circuit you need to increase the output voltage, and you need to do it in a controlled manner so you don't damage anything like output caps. An easy way to do this is to find the feedback resistors and connect a potentiometer in parallel with the lower one (the one that connects to ground). Slowly and carefully reduce the resistance of the potentiometer while monitoring the increasing output voltage. Eventually you'll reach the overvoltage threshold and something will happen (depends on your overvoltage protection circuit, it may shut down or reduce the output voltage). BE CAREFUL and make sure you calculate the feedback resistor values with your potentiometer BEFORE connecting it. If you don't know what you're doing, and you accidentally open up the feedback loop, you may see fire and sparks from your power supply!
