How you make PCB?
Discussion in 'General Electronics Chat' started by shubham161, Aug 5, 2012.
  1. shubham161
    Jul 22, 2012
    50
    look at this video on youtube
    http://youtu.be/tWnfnt2rNO0
    it seems a nice way to make PCB but i am not able to understand it. how he transferred the toner to copper clad without ironing it? he put in under light and did something? was that a light sensitive copper board? can you help me?
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
  3. MrChips
    Oct 2, 2009
    12,622
    3,451
    If you follow the video carefully, he is using a precoated board, that is, a board that is purchased with a layer of photoresist already coated on the board.
    There are two types of resist: positive and negative. The board he is using has a positive photoresist. With a positive resist the areas exposed to light are removed by the photoresist developer.
    With a negative process, the reverse happens. The mask consists of clear images where the traces are wanted. When exposed and developed, the unexposed areas are washed away.
    There are a number of things that you can do differently.
    1) Use as much copper pour or fill as possible to reduce the amount of copper to be etched away.
    2) Instead of ferric chloride I use ammonium persulphate for etchant.
    3) Heating the etching and constant agitation make a huge difference in the time it takes to etch the board.
    4) Leave the resist on the board to prevent the bare copper board from tarnishing. The hot soldering tip will burn through the resist and make the solder joint.
    shubham161 likes this.
  4. shubham161
    Jul 22, 2012
    50
    can you give me links to some online store from where i can purchase such boards? I may not purchase from those stores because they may not ship boards to India but those links will definitely help me to get important keywords for advance search and i'll also know the approx price for such boards.
    and what about the uv light? are they expensive? do i have to make my own circuit?
  5. BMorse
    Sep 26, 2009
    2,675
    234
    He mentioned on the video that he only used a 13 watt CFL bulb, you may also be able to use a 100 watt incandescent bulb, you do not need a UV light....
    If you watched the video all the way to the end, they mention the part numbers and where to get the materials from (Jameco)....
  6. nerdegutta
    Dec 15, 2009
    2,565
    805
    I get the best results with the boards from Bungard
    The UV-Led I bought on E bay was this type.
    At the end of the video, there's some part numbers to Jameco.
    Part 2113244
    Part 2113252
  7. dumindu89
    Member
    Oct 28, 2010
    113
    Why do you recommend persulphate over ferric chloride?
  8. Markd77
    Sep 7, 2009
    2,803
    594
    It's clear so it's easier to see the etching, also it smells better, but both work fairly well.
  9. BMorse
    Sep 26, 2009
    2,675
    234
    Hate to bump this thread, but, I ended up purchasing the kit referred to in the video, (It had the photo developer, 2 presensitized boards, and the etching solution), I thought I would just try it out for kicks and see how well it works (since I do have my own CNC PCB mill, I don't have to use the etch method), it worked quite well, and fairly easy, just follow the included instructions and off you go, all I used was a 24 watt CFL bulb (Spiral kind) to expose the PCB and the etching came out very well if I should say so, but check for yourself, I made this PCB from it for my outdoor wood boiler monitor I used a 44 Pin TQFP PIC16F887, even soldered it on by hand :cool: (and double checked for solder bridges with a 60x magnifier!)
