how you create a magnetized crane
Discussion in 'The Projects Forum' started by Adamf001, Sep 7, 2011.
  1. Adamf001
    Sep 5, 2011
    67
    Hello, im going to create a crane, arm device that can pick up metallic objects using a magnet, then with a press of a button, or switch it turns off. i know you need a soft iron core pole thing for the magnet. i also know kinda how to magnetize a piece of iron but in afraid i am thinking along the wrong lines. so how exactly shall i do it. (the magnet part please) also is there a change i would be able to change the strength with a variable resistor or something?? :confused::confused: please help.
  2. castley
    Member
    Jul 17, 2011
    31
    I hope you realize, a magnet will only pick up objects containing iron.
  3. Adamf001
    Sep 5, 2011
    67
    yea, all ferrous metals will be picked up I get that Much LOL:D
  4. t06afre
    May 11, 2009
    5,939
    1,222
    We are talking toy size her I guess
  5. Adamf001
    Sep 5, 2011
    67
    Yes, each are will be about a foot, 2 arms and a 4-5 inches base to house the components motors switch etc.
  6. JingleJoe
    Member
    Jul 23, 2011
    185
    10
    You are after electromagnets, the simplest one is a coil of wire around a nail; the more coils the stronger the magnet. They require DC and a decent amount of current if I remember rightly.
  7. t06afre
    May 11, 2009
    5,939
    1,222
    No I would not recommend using the nail approach. In this thread posting 5.
    http://forum.allaboutcircuits.com/showthread.php?p=396877#post396877
    One of our more competent members SgtWookie, suggest taking the core out of a mechanical relay. And I think you will be far better of with that kind of solution. Will you be able to get some solder work done either by you or some helper. How will you power the crane electro magnet?
  8. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    or just use the coil out of a relay. You could 'diffuse' the field by adhering a small ferrous disc to one end.
    I used to work on the North American make of diesel electric rail cranes. I'm guessing that those were probably 5ton mags that the fellows would cast out after a rotating the boom some distance. More than once came in to find a whole rig lying on it's side.
  9. t06afre
    May 11, 2009
    5,939
    1,222
    It was just what i ment. But I see now that i was not as clear as I should have been. My bad;)
  10. wayneh
    Sep 9, 2010
    12,375
    3,226
    I got your point, and completely agree. Winding coils can be exciting when it finally works, but really it's a lot of tedious work when you can find one so easily, ready-made. An old tape-based answering machine will often have several solenoids in it. Not big ones, though. A DIYer has a challenge to get enough length of a thin enough wire to limit the current while getting a decently high number of turns. Fifty turns of fat copper wire around a nail works, but draws a huge current for not much field. The optimum solenoid coil is nearly square in cross section; it's almost as fat as it is long.
