How would you analyze this circuit?
Discussion in 'General Electronics Chat' started by Pulsed, Sep 10, 2012.
  1. Pulsed
    Sep 10, 2012
    41
    How would you analyze this circuit in the picture attached using Kirchhoff's laws?
  2. Dodgydave
    Jun 22, 2012
    5,159
    772
    V1= V2 = 7volts
    I1=I2+I3= 8Amps
    I3=I4= 1Amp
    V3=I3x3ohms = 3Volts
    lizard likes this.
  3. Pulsed
    Sep 10, 2012
    41
    What steps did you take to get to those conclusions in a time order?
  4. sbixby
    May 8, 2010
    57
    10
  5. t06afre
    May 11, 2009
    5,939
    1,222
    In general kirchhoff's voltage law=mesh analysis. The wiki site looks OK http://en.wikipedia.org/wiki/Mesh_analysis But you will for sure find a lot of stuff regarding this using Google. Take some time to find the explanation that you find fit your way of understanding best
  6. ErnieM
    Apr 24, 2011
    7,442
    1,628
    (I'm using R as my symbol for ohms)
    By inspection,
    i1 = -8A
    i4 = i3
    Applying Kirchhoff's current law to the top center node yields:
    -i1 - i2 - i3 = 0 but since I hate negatives, multiply both sides by -1
    i1 + 12 + i3 = 0
    and since we know i1:
    -8A + i2 + i3 = 0
    rearrange & solve for i2:
    i2 + i3 = 8A
    i2 = 8A - i3
    the voltage of the 3 legs is equal, so:
    i2 * 1R = i3 * 3R + 4V
    substituting for i2:
    (8A - i3) * 1R = i3 * 3R + 4V
    8V - i3*1R = i3*3R + 4V
    4V = i3*3R + i3*1R = i3*4R
    i3 = 1A
    V3 = i3 * 3R = 1A * 3R = 3V
    knowing i1 and i3 gives us i2:
    i2 = 8A - i3 = 8A - 1A = 7A
    V2 = 7A * 1R = 7V
    It would be useful to check this answer. One way would be to make a Thévenin equivalent of the resistors and the voltage source:
    Rth = 1/(1/3R + 1/1R) = .75R
    Voc = 4V * 1R/(1R + 3R) = 4V * 1/4 = 1V
    As all of the 8A source flows into the equivalent circuit:
    V2 = 8A * Rth + Voc = 8A * .75R + 1V = 6V + 1V = 7V
    which agrees with our previous answer.
  7. steveb
    Jul 3, 2008
    2,433
    469
    I would analyze it by inspection running the numbers in my head. Not that I'm particularly good at doing that in general, but this one is easy. You have a Norton current source on the left and a Thevenin voltage source on the right. You can transform either side and play all kinds of mind games with it.
  8. shubham161
    Member
    Jul 22, 2012
    50
    This is a pretty easy circuit.
    resistance of ideal current source is infinite. so the current produced by voltage source is not going to go towards current source and hence the two resistances 1 ohm and 3 ohm are in series connected to 4 V supply. current can be calculated from here. current flowing in series resistances are same.
    since now we figured out the current flowing because of voltage source its easy to calculate current due to current source.
    now all currents are figured out. apply ohms law V = IR to calculate the voltage drop across individual resistors.
  9. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Nope... the 8 amps from the current source MUST go thru both the 1 ohm resistor and the 4V voltage source.
    And the current in each resistor is different as they are not directly in series.
  10. WBahn
    Mar 31, 2012
    18,089
    4,917
    Your reasoning is way off. The two resistors are most definitely not in series. In fact, the currents in them differ by 8A.
    There are at least half a dozen ways to analyze the circuit and they are all pretty much the same difficult. I would recommend analyzing it several different ways to make sure you get the same answer. The simplest one, as I see it, is to convert the 8A current source and the 1R resistor into an equivalent thevenin circuit. At that point you can determine the current in 3R resistor and the voltage source and then use that to determine the current in the 1R resistor (in the original circuit). You can do it all quite easily in your head.
  11. shubham161
    Member
    Jul 22, 2012
    50
    i am telling the general case, not specific for this problem.
    its my crude method for analyzing simple circuits directly without source transformation and without using any complicated equation.
    remove the current source. see them as voltage source connected to 1 ohm and 3 ohm resistance. and now they are in series. so there are (3+1) ohm resistance connected to voltage source. therefore current leaving/entering the voltage source is 4/(3+1) = 1A.
    now current leaving/entering the current source is given as 8A. This 8 ampere current will flow from 1 ohm resistor (this time i have neglected voltage source).
    total current from 1 ohm resistor is the algebric sum of (what found neglecting voltage source) + (what found neglecting current source).
  12. steveb
    Jul 3, 2008
    2,433
    469
    You are describing the superposition method, and that is certainly a good method for this problem. Personally, I would not describe this as a crude method.
  13. shubham161
    Member
    Jul 22, 2012
    50
    yes i used the superposition method but it was with some modification. That modification is good for this particular problem but it's not a good idea to adopt such methods. so i removed the attachment from my last post so that OP don't learn the bad habits.
  14. WBahn
    Mar 31, 2012
    18,089
    4,917
    He's describing the concept of superposition, but not doing so correctly or validly. You don't "neglect" the sources, you turn them off (i.e., set them to zero output). For a current source, this means effectively removing it from the circuit. But for a voltage source it means shorting it so that it have 0V across it but no restriction on the current rhrough it.
    That his method is invalid is evidenced by the fact that it produces the wrong answer for this problem. He gets 1A flowing downward in the 1R resistor when neglecting the current source and 8A flowing downward in it when neglecting the voltage source for a total of 9V. But, used properly, superposition gives 1A flowing downward with the current source turned off and 6A flowing downward when the voltage source is turned off.
  15. Pulsed
    Sep 10, 2012
    41
    Thanks guys! Your help is invaluable to me as I am new to the concepts of Kirchhoff's laws!! So in looking at another example, how would you make a KVL equation for the loop indicated? The thing that really gets me confused is R3, what is the polarity of the voltage across it? How do you deal with it?
  16. justtrying
    Mar 9, 2011
    329
    405
    assign polarity based on your loop. Key is being consistent, your final answer will correct itself. In these problems, if your final answer is negative, it means that current runs in the direction opposite to what you assigned.
  17. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Start by assigning a loop current for each of the three loops:
    For each loop write an expression for each element. We assign a positive polarity for each element when the assumed current enters it.
    Example: for the I1 loop, R2 has a current of (I1-I2), R1has a current of (I1-I2), and we enter the + terminal of the V source, so:
    (I1-I3)*R2 + (I1-I2)*R1 + V = 0
    similarly for the other loops:
    (I2-I1)*R1 + (I2-I3)*R3 + I2*R4 = 0
    (I3-I2)*R1 + (I3-I2)*R3 + I3*R5 = 0
    Now you have 3 expressions in 3 unknowns (I1, I2, and I3).
    Have at it!
      File size:
      4.3 KB
      83
  18. Georacer
    Nov 25, 2009
    5,151
    1,266
    ErnieM likes this.
  19. markbool
    Jul 5, 2012
    I agree with Dodgydave...and this is simple, easy and nice explanation.
    Dodgydave likes this.
  20. Pulsed
    Sep 10, 2012
    41
    I do have a few more questions, if that is okay?
    Attached is my attempt at solving this circuit using the node method.
    Please, if you can, tell me where my mistakes are in my thought process.
    The thing that really gets me is the signs, the signs of the current and voltage. I suppose you can find if you got the voltage polarity correct buy going around the given loop and seeing if the voltage sums to zero. Direction of current still confuses me.
    And if I don't understand the former, how can I use them to find the sign of the wattage!
    I thought voltage and current sources gave out power therefore their power was given in -W. But upon entering the answers I got current power in watts wrong. I entered -56W but the correct answer was +56W.
    The questions were:
    The value (in Volts) of
    v1
    is: 7
    correct
    The value (in Amperes) of
    i4
    is: 1
    correct
    The power (in watts) coming out of the current source: -56
    incorrect
    The power (in watts) coming out of the voltage source: -4
    correct
    The power (in watts) dissipated in the
    resistor: 49
    correct
    resistor: 3
    correct
    Many thanks!!
