how would i be able to change this?
Discussion in 'The Projects Forum' started by bamaboy30, Dec 2, 2009.
  1. bamaboy30
    Dec 2, 2009
    I've found a circuit that ive need but.................
    i need the LED to use its owns battery
    Thank you
  2. mik3
    Feb 4, 2008
    4,846
    63
    Give a better explanation.
  3. Bernard
    Aug 7, 2008
    4,240
    414
    Replace existing LED with optical coupler , might need a transistor to boost output to drive LED.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    It's depending on the voltage drop of the diodes. You are not using a battery, you are using line voltage. This can be dangerous, caution is important here.
    The LED is an old one, on of the types that use 1.5V dropping. Modern LEDs drop 2.5, you will need more 1N5404 diodes to drop more voltage.
