how will solve this circut
Discussion in 'Homework Help' started by watyoung, Nov 16, 2014.
solve this
  1. 5
    3 vote(s)
    100.0%
  2. 5
    1 vote(s)
    33.3%
Multiple votes are allowed.
  1. watyoung
    Nov 16, 2014
    solve this circut
  2. shteii01
    Feb 19, 2010
    3,518
    515
    How much?
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    As this looks like homework, I moved it here.
    Show us your calculations and we can check them and give hints where you went wrong.
    Bertus
  4. WBahn
    Mar 31, 2012
    18,093
    4,920
    With just a bit of practice, you should be able to solve this by inspection. Hint -- that diagonal wire drastically reduces the complexity of the circuit.
    But in the meantime, do what the question says, which is reduce it one step at a time. You might try first redrawing the circuit in such a way that the all resistors that are electrically connected to the negative side of the source are drawn vertically with one end tied to the bottom node in the picture.
  5. Dodgydave
    Jun 22, 2012
    5,167
    777
    roughly 4 ohms
  6. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Reminds me of one of the midterm questions eons ago when I took electronics, it was a cube consisting of 1ohm resistors, and it required the calc of the resistance across two diag corners.
    Max.
