Hi All,
I'm new to this forum. I'm making a pcb with flash memory IC that plugs into a Microchip PIC32 eval board. This will add an ONFI flash interface to the uC's peripheral bus. I'm not a hardware guy and my 1st flash board performed poorly. The problem I saw was that the supply voltage at the flash IC on this board was very noisy: +/- 0.5V on a 3.3V supply. On an oscilloscope I could see that the bus signals were flakey when the supply voltage fell out of spec. This time I'm trying to follow better layout practices. I'd like feedback about the new layout before I send it to the boardhouse.
Do you see anything that I should add or change to make a better operating board? Is this similar to the way your board might look if you made this? Also anyone interested in the design for themselves can just pm me for the project files.
Here are some things I'm doing *differently* this time because of guidelines I found on the web:
- "Use a ground plane and a VCC plane. Avoid long slots in ground planes."
- "Make ground vias large in diameter."
- "Run ground traces along-side VCC traces. Separate sensitive signal traces with ground traces."
- "Avoid running signal traces in parallel."
- "Make all bus signals equal length."
- "Keep traces for bypass caps as short as possible and as close to the IC's VCC pin as possible to reduce inductance. Place caps between the trace to the plane and IC pin instead of behind it."
- "Reduce inductance by dividing the value of one bypass cap into several smaller value caps connected in parallel."
- "Use reverse geometry bypass caps to reduce inductance, i.e. the cap should be wider than its length."
- "Use terminating resistors on buses to reduce signal reflection."
- "Keep the distance between signal lines more than twice the width of the signal line."
- "Avoid long traces for lines to an analyzer tool, and connect analyzer lines to each signal line using a resistor."
- "Use decoupling filters on power supplies going to circuit subsystems."
The eval board has a 132 pin connector that normally plugs into a breakout board. This connector carries the signals for most all uC pins. My flash board will stack between the eval board and breakout board, and still carry the signals between the eval and breakout boards.
Fundamentally the board is simple: it has a flash IC and a header to connect analyzer probes to monitor signals. There are "terminating" resistors in series between the connector and flash pins, and "damping" resistors going to the analyzer header. I'm using resistor values I found from other designs.
I'm using the free version of Eagle, so I can only make 2 layer boards. The board is about 2 x 3 inches. I added pics of the schematic and board layers.
To describe my pics of the layout:
- I placed the ground plane, flash chip, and 4 resistor array ICs on the bottom side (bottom side has blue traces).
- I made a small power plane on the top side for the bypass caps. The bypass caps, some 0 ohm jumpers, individual resistors, and the header for the analyzer probe are all on the top side (top side has red traces).
- I tried placing all traces on the top side to reduce slots and holes in the bottom side ground plane.
- I filled the unused areas of the top side with a ground plane so that ground traces run between signal traces.
- It's not shown in these pics, but I'm currently rerouting traces from the connector so that all bus signals are of equal length. (Hopefully the traces on the eval board are equal length too!)
- I'd like to add a decoupling filtering between the power supply pin on the connector and the power plane but I don't know what to use.
