how was the quiescient current set in this transistor power amplifier?
Discussion in 'Homework Help' started by Santa klaus, Aug 31, 2015.
  1. Santa klaus
    Nov 16, 2014
    28
    the base quiscent voltage of the diff pair is -0.4V and the emitter voltage -1.0V. This gives a quiscent current of 2mA. I don't understand. Why is the base -0.4V or the emitter -1V ? did the author predict that,how? I tried simulating only the diff pair with no input and i don't get the same quiescent values. [this is from the Art of Electronics]
  2. Santa klaus
    Nov 16, 2014
    28
    never mind i got it. we use the relation Ic = Hfe x Ib and the input resistor to set the input voltage. My Hfe in simulation was not 250 that's why it didn't work
  3. MikeML
    Oct 2, 2009
    5,450
    1,066
    Note that both bases are effectively supplied from 0V. The base resistors cause a small voltage drop. V(ee) has to be -0.6V or so below the bases, so V(ee) is about -1V, which means the current in R3 is about 14/6800 = 2mA. Since the diff amp is initially balanced, then the current in the emitters is more or less equal, or ~1mA each.
    Notice that I didn't need to make any assumption about Hfe.
    GopherT and Santa klaus like this.
  4. WBahn
    Mar 31, 2012
    18,069
    4,905
    Sure you did. Otherwise how did you get that V(ee) was -1V and not -0.7V or -1.5V or some other value?
    You can converge on it very quickly. First assume that there is no voltage drop across the base resistor (infinite beta) and you have Ve ~= -0.6V putting 14.4V across the 6.8 kΩ resistor yielding 2.12 mA. Half goes down each transistor (assuming the output is nulled) giving an Ic of 1.06 mA. The stated beta is 250 giving a base current of 4.2 uA. With a 100 kΩ base resistor, that's a voltage drop of 424 mV. That's almost certainly good enough, but you could go another round and say that Vb = -0.424 V making Ve = -1.024 V (and noting that we don't know Vbe to within more than about 100 mV) making Ic = 1.028 mA making Vb = -0.411 V. Given the uncertainty in Vbe, there's no point in going any further.
    Santa klaus likes this.
