HOW TO: Wireless push button solenoid?
Discussion in 'The Projects Forum' started by stanman11, Mar 4, 2011.
  1. stanman11
    Nov 23, 2010
    230
    With minimum electrical pieces used. im trying to ad a solenoid to a already made circuit board OR!!. compile a mini circuit i can control selonid with.
    push button to a wireless popper solenoid. i have radio transmitting crystals. From xmod rc cars
    how do i make this work wirelessly?
  2. wayneh
    Sep 9, 2010
    12,379
    3,232
    Your needs are unclear. What exactly are you trying to do?
    "compile a mini circuit i can control selonid with."
    Huh?
  3. stanman11
    Nov 23, 2010
    230
    I'm Dyslexic sorry lol.
    I'm trying to control a solenoid with a wireless transeiver, with a wireless button receiver.
  4. wayneh
    Sep 9, 2010
    12,379
    3,232
    Oh, OK, thanks for making it crystal clear. The RC experts here I'm sure can give you a simple solution.
    I think they'll want to know how much current (at what voltage) is required to trip the solenoid. By solenoid, do you mean relay, to control an electrical circuit, or are you needing the mechanical action of a solenoid?
  5. stanman11
    Nov 23, 2010
    230
    mechanicle electromagnet solenoid.
  6. stanman11
    Nov 23, 2010
    230
    well i want to ad a button to my remote which uses 9v.
    then i want the solenoid to operate on the car which uses 9.6v, when i press the little button on the remote.
    prolly wont be possible to wire it in to the diagram so next option would be making a small wireless transmitting device/ciruit.
  7. wayneh
    Sep 9, 2010
    12,379
    3,232
    I suggest starting a new thread titled something like "Help adding solenoid control to RC Car" or something like that, to catch the attention of the RC experts around here. Make it clear that you need either an add-on to the existing controls, or a completely separate circuit with Tx and Rx, sharing only the existing power sources and enclosures. Of course if I've gotten anything wrong, correct it.
  8. stanman11
    Nov 23, 2010
    230
    K thnx!! that really helps lol its hard for me to explain what my needs are but in my head its perfect lol
