How to wire up LCD LED Interface Pins
Discussion in 'General Electronics Chat' started by Hurdy, Mar 18, 2014.
  1. Hurdy
    Thread Starter Senior Member
    Feb 27, 2006
    137
    Firstly, thank you for taking the time out to read this post.
    I recently purchased a MIDAS MC21605E6W-SPTLYI 2x16 I2C LCD. The datasheet doesn't really provide any information regarding the connection of the LED+ & LED- pins to Vdd (3v) and GND.
    Should I connect the LED+ pin to Vdd (3V) via a resistor? If so, what value of resistor should I use?
    Here's a link to the PDF datasheet: MIDAS LED DATASHEET LINK
    Again, thank you very much for your time.
    Rob
  2. Brownout
    Jan 10, 2012
    2,375
    998
    I can't tell either.
  3. spinnaker
    Oct 29, 2009
    5,074
    1,176
    That is just the backlight. Add an appropriate current limiting resistor and connect to your 3V. Datasheet should give forward voltage of the LED so you can calculate the resistor.
    Hurdy likes this.
  4. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Well looks like it does not have max current for forward voltage of the LED. You could take a guess based of the color.
    Hurdy likes this.
  5. Hurdy
    Feb 27, 2006
    137
    Hi both,
    I really appreciate your prompt responses.
    The datasheet states the following:
    LED Forward Voltage: 3.8V - 4.2V
    LED Forward Current: 15mA
    So assuming I use ohms law I get the following:
    R = 4 / 0.015 = 266 ohms.
    My next question is, if the Vdd for the LCD controller is 3v, is it common for the LED backlight to require a 4v supply? Currently everything in my circuit design uses 3v. Does this mean that I'm going to need a 4v supply just for the backlight LED?
    Many thanks for your input.
  6. Brownout
    Jan 10, 2012
    2,375
    998
    It might. 3v isn't enough forward voltage for some types of LED's. You datasheet also shows two LED's in series. Are they 4V wired together, or 4V each? Can't seem to tell. I would connect a 15mA current and measure the voltage, and measure the resistance with a DMM.
  7. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Sorry I must have missed that in there. Your forward voltage is going to be based off color. Are you certain that is the only range? If that is it then you won't be able to light the backlight. Blue does have a pretty high forward voltage. What color is the backlight? If it is yellow, green or red, I would be surprised if it was really that high.
  8. Hurdy
    Feb 27, 2006
    137
    Thanks Brownout. I think this will be the best option. But of a bummer that I will need to supply another Voltage rail to my circuit. Such is life though.
  9. spinnaker
    Oct 29, 2009
    5,074
    1,176
    If the display is 3V then your backlight might light with 3V. I would give it a try. Use 20ma as your current just to play to safe.
    Hurdy likes this.
  10. Hurdy
    Feb 27, 2006
    137
  11. spinnaker
    Oct 29, 2009
    5,074
    1,176
  12. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Yep on closer inspection of the datasheet, looks to me like they are in series. Bummer.
    Strange it says LED 1 with 2 dies.
      File size:
      35.3 KB
      105
    Hurdy likes this.
  13. Hurdy
    Feb 27, 2006
    137
    yea a real bummer.
    Oh well, I will need to create one power rail for 3V for my chips and another 4v rail just for the backlight LED.
    Some testing is required first though.
    Really appreciate your time and help with this.
    Rob
  14. Brownout
    Jan 10, 2012
    2,375
    998
    If you just supply 5V for the LED, you can just connect a 3V regulator to the 5V supply for the chip. Or else just run the display on straight 5V. But before you do anything, I would supply 15ma to the LED and verify the voltage.
    Hurdy likes this.
  15. Hurdy
    Feb 27, 2006
    137
    Just had a response from MIDAS regarding the backlight LEDs.
    The LEDs typically need 4.1V at 30ma
    I was advised to use a 5V supply with 30R resistor.
    So how do you calculate the resistor required?
    Ohms law tells me the following:
    R = V / I = 5V / 0.030A = 166.66R
    166.66R certainly isn't 30R.
    Here's a copy of the datasheet that was emailed to me from MIDAS support (download PDF)
    Many thanks,
    Rob
    /************* EDIT *****************/
    I found an LED calculator here when Googling.
    It recommends 33R, which matches MIDAS' response.
    I guess I didn't consider supply voltage as well as the diode forward voltage.
  16. Brownout
    Jan 10, 2012
    2,375
    998
    (5 - 4.1)/.03 = 30 ohm.
    Hurdy likes this.
  17. Mickster
    Member
    Jan 10, 2010
    25
    11
    See Brownout's answer above.
    Supply voltage, minus diode forward voltage, divided by intended drive current, equals resistance.
    Hurdy likes this.
  18. Hurdy
    Feb 27, 2006
    137
    Thank you guys, really appreciate it.
    There's a good YouTube video here describing how LEDs and limiting resistors work if anyone else is interested.
