Heavydoody
- Joined Jul 31, 2009
- 140
Thanks for the explanation. I never thought about it that way. So the LED is like any other diode and it will always (within reason) drop the same voltage, similar to a Zener. This creates a basic voltage regulator circuit in conjunction with the current regulator to prevent overall circuit overload. The load is also the voltage regulator. That's pretty cool. Thanks again.>
Regulating the current to a set value (in this case, 20 mA) is exactly what
we want to do here in order to have the LED work properly. The point is
that, since the current through a diode depends exponentially on the
voltage drop, the only reliable way of running a LED is via a current
source, such as a constant voltage source plus dropping resistor or a
current limiting diode or a regulator IC hooked up to regulate current.
No, if 20 mA are flowing through the diode, the voltage drop across the
diode will be 3.3 V, so the LED will dissipate 66mW, which is just fine.
240 mW is the dissipation across the whole circuit --- the remaining
174 mW will go into heating the dropping resistor.
