I am trying to hook up a dimmer rocker switch (rated for 12V, 10A) to run a LED dimmable bulb that runs on 12V. The switch has three connectors - Battery, Load and ground. How do I make the connections? I have 2 wires bringing 12V supply and 2 more wires for LED bulb. Datasheet attached for the dimmer switch. The mfgr said: connect i/p to Battery & Ground and o/p to Load and second wire of load goes to chasis ground, so does this mean second wire of load goes to "Ground on the switch? Thanks.
Mayur
Mayur
