I have a Von Weise motor with the following specifications, I have included 3 photos for your ready reference.
I am using this motor for a project of mine, so I would appreciate it if you can provide a wiring diagram to show each of the six wires purpose, I im interested in Reverse and Forward connection.
I do appreciate any help I can get.
Regards
Cid
Von Weise class B Linear Actuator,
Label Shows:
Model: V05119AU76
Type: VWG-1
115 Volt AC
60 Hz
1 PH
Serial E3197
RPM: 1550
1/10 Hp
1.6 Amp
Ratio: 19:1
Output Min 10 IN/MIN-1000 LBS
Class B
Capacitor Rating 20 MFD
Int. Duty
Regards
Cid
Label Shows:
Model: V05119AU76
Type: VWG-1
115 Volt AC
60 Hz
1 PH
Serial E3197
RPM: 1550
1/10 Hp
1.6 Amp
Ratio: 19:1
Class B
Int. Duty
