How to wire a motor with sensors to a DPDT switch?
Discussion in 'General Electronics Chat' started by borgqueenx, Oct 6, 2016.
  1. borgqueenx
    Oct 6, 2016
    I want to purchase the following products:
    https://nl.aliexpress.com/item/ONE-..._6&btsid=d52fbf7a-fcaf-478b-8fa2-a15ba52e3dd0
    https://nl.aliexpress.com/item/10Pc..._6&btsid=a76cbacf-7191-4655-b929-07ec0ba95daa
    I want to wire the switch to the motor so in 1 positions it goes forwards, in the second(middle) goes backwards and in the last position goes off.
    Is there a way to achieve this? I am used to working with drones/UAV's, and there you have a 3-wire phases, but they are not on that little motor? Will reversing volt work? How should i wire this?
    Thanks!
  2. Dodgydave
    Jun 22, 2012
    5,137
    767
  3. Alec_t
    Sep 17, 2013
    5,956
    1,132
    It would be better if the 'off' position were the centre one, so that the motor isn't abruptly switched from one direction to the other (which is stressful for the motor and gears).
  4. borgqueenx
    Oct 6, 2016
  5. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    I don't speak Dutch but it seems there is some kind of encoder on the motor?
    I see now it is just a DC motor with a hall effect sensor that has four wires, and two for the DC motor.
    You don't need the sensor to run it, just the two motor wires if preferred.
    Max.
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    @MaxHeadRoom : On the bottom of the page it says it has some hall sensors:
    Bertus
  7. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Yes, I noted it in my last post.;)
    Max.
  8. borgqueenx
    Oct 6, 2016
    thanks for the help everyone!
