I have created i diagram that i have been trying to figure out how to wire for the past two weeks. Any help would be greatly appreciated.
Some non-english speaking countries translate stop/start to open closeWhat are you trying to do? Are you trying to open and close something? Or are you trying to turn something on and off?
What exactly are you doing?
i have dual electric exhaust cutouts that open and close to make the exhaust louder when open and quiet when closed. i want to be able to open them and close them at any point (stop half way, 3/4 of the way, etc.) just by pushing and letting go of the buttons.What are you trying to do? Are you trying to open and close something? Or are you trying to turn something on and off?
USA. i am not sure about the rating of the motors but the company states that they can be hooked up to a 12v source and it comes with a 1amp inline fuse.snaubert6783......thanks, that saves a lot of questions. What country are you in?
I am assuming the motors are 12 volt. What is the motor current rating?
i am not 100 percent educated in this field but i believe that you are showing what i want to accomplish. For a recap, both buttons would be open until i press and hold one of them (red led button press and hold to open both motors and the blue led button press and hold to close both motors). question, why would i connect anything to the nc posts?If I understand the switch operation correctly, below is how to connect them to the motors.
This assumes the red motor wire closes the motors. If not then reverse the red and black motor wires.
(I didn't show the LED wiring but I assume you can do that).
i see.crutschow is using the switch contacts to switch the polarity to the motors.
