How to use voltage regulator?
Michael George
Joined Feb 8, 2015
53
I have some questions about using voltage regulator. Would you give me a hand, Please?
If I removed C1, It will become an open circuit. Is that good or bad? I think its better to remove it because it changes the value of C2 and The voltage regulator requires C2 not C1.
Second, Would you tell me how to calculate the values of C2 and C3, Please?
I will use LM7805CV
Thank you very much,
tracecom
Joined Apr 16, 2010
3,944
C1 is the main filter capacitor; if you remove it the DC will pulse. The values for C2 and C3 are wrong and the values aren't calculated, but are taken from the datasheet for the LM7805. C2 should be .33uF, C3 should be .1uF, and C4 should be added: 10uF.
Jaytronic
Joined Mar 2, 2016
6
Unless you are doing something different I would stick with the typical application circuits provided in the datasheet. Most linear powers require a cap (C3) for smoothing out the full wave voltage from the diode bridge, C2 is there for additional filtering, C1 is for filtering/smoothing the output voltage.
There is no reason that I can think of that requires any of those caps to be removed. If you want a clean 5VDC then leave them there. As for calculating the values for the caps, it really isn't necessary to do so, just stick with the typical application circuit.
AnalogKid
Joined Aug 1, 2013
11,055
1. If I removed C1, It will become an open circuit. Is that good or bad?
2. I think its better to remove it because it changes the value of C2 and The voltage regulator requires C2 not C1.
1. Bad. Do not remove C1.
2. Incorrect. The voltage regulator requires a DC input that *always* is greater than approximately 7 V. This is stated clearly on the datasheet. The value of C1 necessary to make that happens depends on the transformer and the load on the regulator output. Also, the voltage regulator requires an energy source with a very low AC impedance. Both a large bulk filter capacitor and a smaller, high frequency bypass capacitor combine to make that happen.
ak
Michael George
Joined Feb 8, 2015
53
Thank you all very much for your answers,
C2 should be .33uF
If I did not remove C1, I think the capacitance at the input of the voltage regulator would be 470.33 uF and datasheet says we need only 0.33 uF. Is that ok?
This website says: A large reservoir capacitor is not necessary, as the regulating action of the I.C. will reduce the amplitude of any AC ripple (within its maximum input voltage range) to just a few millivolts at the output.
Here is the link of the website: http://www.learnabout-electronics.org/PSU/psu23.php
This is their schematic:
Is it a good design? or the first one is better?
Thank you,
Michael George
Joined Feb 8, 2015
53
Hello HitEm True,
This is a project for my collage. I'm a student at the faculty of engineering (electrical engineering). I can not buy one :) I have to design and build the project by myself. Also, I would like to learn. Anyway, Thank you for your answer.
HitEmTrue
Joined Jan 25, 2016
32
Hello HitEm True,
Ok. Well, what else do you see different between the two designs you've posted, besides the removal of C1?
Evanguy
Joined Dec 21, 2014
85
You should use the drawing provided by the chip's maker. its in the data sheet. you wil not improve it by removing parts. they are the minumin parts needed to have it function as intended. why do you so eagerly want to change it with no understanding of why its here and what its doing? And why do you trust that site you linked more then the data sheet. the makers of the regualtor have done more testing the circuit then probably anyone on earth.
shteii01
Joined Feb 19, 2010
4,644
Thank you,
The manufacturer provided you with a RECOMMENDED design in the datasheet. You can ignore the manufacturer, like the people from the website you keep quoting. You, the user, get to decide if you will use manufacturer recommended design or design from some people on the internetz whose engineering credentials you don't know.
WBahn
Joined Mar 31, 2012
30,072
I will use LM7805CV
As others have said, how you use a voltage regulator is in conformance with the manufacturer's data sheet. Now, you can go charting your own path (and sometimes that the only way to do it), but you will be sailing in uncharted waters and there be demons off the edge of the map.
The presence of C1 does not change the value of C2. Why there are two capacitors is that each one deals with a different part of the noise. C1 softens the output of the bridge so that you have a mostly-DC signal with some ripple on it. The size of C1 is dictated by the current draw and how much ripple voltage you can tolerate. C2 is intended to feed the higher frequency signals that larger caps can't handle because of their higher effective resistance.
The values of C2 and C3 (and often other recommended components) are contained in the data sheet (usually).
Draw a vertical line between C1 and C2. Everything to the left of the line is in a black box labeled, "Unregulated Power Supply." You can't see C1, so don't worry about it when thinking of the stuff to the right of the line that is in a black box labeled, "Voltage Regulator." Now, having said that, the claim that you "can't see C1" isn't really true, but for this discussion it's close enough.
tracecom
Joined Apr 16, 2010
3,944
Thank you,
Asked and answered multiple times. Do it however you want. And it's college, not "collage."
AnalogKid
Joined Aug 1, 2013
11,055
No.
No. That is a gross overstatement that is misleading. It is correct technically, but only if you read ALL of the words and understand what they mean. You don't. You highlighted the wrong phrase.
The 7805 applications circuits assume that the input is pure DC with no ripple. No ripple. Zero ripple. To get close to that the output of an AC/DC power converter must have a large filter capacitor. The datasheet is describing the chip, not what drives the chip. If you keep asking the same question you will keep getting the same answer.
ak
