How to use toroid transformer.
Discussion in 'General Electronics Chat' started by Mr.Alan, Aug 15, 2016.
  1. Mr.Alan
    Aug 15, 2016
    6
    I got a aduio toroid transformer. The transformer has 6 cables Red,green,blue,brown and 2 yellow cables. I want to know what to do with the cables and how to use the transformer. I just startled with electronics and im intrested in aduio so it would be good if you can send a totorial on aduio electronics.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Mr.Alan likes this.
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    Can't help - my crystal ball is in the shop...........................
    Dr.killjoy likes this.
  4. blocco a spirale
    Jun 18, 2008
    1,461
    370
    I'm going out on a limb here and assuming you mean an audio transformer. So that would be an audio output transformer or is it a power supply transformer from an audio amplifier?. Unfortunately there are millions of different transformers out there and they aren't defined by the colours of the wires sticking out of them.
    There is no such thing as a totorial/tutorial on audio electronics; it's quite a big subject and if you've done any research at all you will already know this.
  5. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    I'm guessing 3 input and 3 output, push pull, measure the resistance between all 6 and document.
    Max.
  6. shortbus
    Sep 30, 2009
    4,096
    1,692
    I'll go out on one too.:) I'm assuming it's a toroidal transformer for the power supply. Like the ones Antek sells. Very popular for audio amplifiers. http://www.antekinc.com/200va/
  7. Mr.Alan
    Aug 15, 2016
    6
  8. ci139
    Member
    Jul 11, 2016
    341
    39
  9. #12
    Nov 30, 2010
    16,704
    7,354
    The yellow wires are obviously very different from the other two pairs. First guess: power goes in the yellow wires and you have two equal and separate output windings of low voltage and high current.
  10. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Sure looks like a power transformer. I'd guess the thin yellow wire pair is the mains-input primary winding and each thicker twisted-wire pair is a respective secondary winding. As for the ratings of the windings it's anyone's guess.
    Edit: #12 beat me to it.
    #12 likes this.
  11. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Measure resistance to see if they are separate pairs, by the apparent gauge of the larger conductors, they would be secondaries if a mains Txfmr.
    Max.
  12. Mr.Alan
    Aug 15, 2016
    6
    Its scary becuase it says that 230 volts is going in to the yellow wires and the yellow wires are super thin.
  13. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Sounds more like a mains transformer with the standard colour of Blue & Brown as power?
    If the two yellow show shorted then they could be a thermal sensor?
    Max.
    #12 likes this.
  14. crutschow
    Mar 14, 2008
    13,508
    3,384
    Where does "it" says that? :confused:
    The yellow wires are thin because they carry less current then the lower voltage output windings.
  15. markdem
    Member
    Jul 31, 2013
    98
    48
    I agree with Max. Primary in on the blue and brown, output on red and green.
    I am going to guess that the yellow is a aux winding that will give a lower voltage.
    Have fun.
  16. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Yes, we need to confirm who/what is that says it is a Audio transformer?
    If there is data on the transformer, lets see it.
    Max.
  17. Mr.Alan
    Aug 15, 2016
    6
    found new information it says that yellow is 230V input and the green/red are 2x15v and the blue/brown is 300v
