How To Use This Meter?
Pjam
Joined Apr 25, 2016
8
First I should say Hi to everyone here and also warn you, I don't have a clue what I doing, I'm probably dangerous to myself and others! heheh
But, I'd love to use this somehow. Ideally in a box / domestic bulb / dimmer arrangement.
It was designed many years ago in a very non-domestic situation. It was in a UK railway switch room (600V I think!)
Anyway, how can I use it in a way that'll make that needle swing? Is there any practical way? It is a beauty I think.
Dodgydave
Joined Jun 22, 2012
11,305
Its an AC ammeter, you will need to remove the shunt wire and diodes inside, and you can use it as a simple voltmeter or other range ammeter by altering the shunt resistance.
Pjam
Joined Apr 25, 2016
8
Ah !
Shunt wire Dave? Can you tell me any more? what am I looking for? Imagine you talking to a 5 year old hahah
Maybe I should get a photo of the guts :confused:
KL7AJ
Joined Nov 4, 2008
2,229
I believe that might be a thermocouple ammeter...if so you do NOT want to modify it....it's far too valuable in its native state. If you have an HF transmitter and a dummy load, you can see if it reads with RF excitation.
Picbuster
Joined Dec 2, 2013
1,047
Help!!!! stop!!!!!! antique do not modify keep as is. should be in a museum.
The coil will, when current flow, move the L shape part connected to the arm.
Size of coil number of windings will define reading.
Please promise the whole world that you keep this as is.
30,823
That is a moving iron ammeter that measures RMS DC or AC.
You don't see too many of those.
I would suggest you donate it to a school that teaches physics.
You should also document it by taking lots of photographs.
Pjam
Joined Apr 25, 2016
8
:) Hahhah. OK I promise. Just to really show off I have a pair of these!
Must say, even without knowing much about the thing, it is impressive ....... does it have any sale value?
Pjam
Joined Apr 25, 2016
8
Thanks to everyone for the good advice.
I did a little research, EEC was right there at the beginning of electrification of trams and railway! Amazing.
Pjam
Joined Apr 25, 2016
8
It looks like a moving iron meter driven via a 5A current transformer. feeding it with 5A ac should get it moving.
Thanks Prof. If you think this might work then I should take a closer look ......... hmmmmm a 5A current transformer. What kinda thing did you have in mind?
