how to use pic16f877a and lm3914 to control ten led
how i can program that and whats cricut
how its work ?
how its work ?
I was asking myself the same question, and I think that if you add a capacitor to the PWM output it might work.can i use PIC digital output pwm
For the values you need to divide the maximum value of the PWM by the number of LEDs, and multiply it by the value you want to output; assuming that Vcc lights all LEDs and 0v lights none. For example: to light LED 3, given that the maximum value of the PWM output is 256, would be:but what value to turn 1 led , 2 led if i have osc 4mhz
I would be really interested in knowing if you get it working -I'm learning too- or to help if you need anything else.thanks i will try but is very diffecult
Thread starter | Similar threads | Forum | Replies | Date |
P | How ADC value stores inside ADRESH and ADRESL register for pic16f877a .. #2 | Microcontrollers | 1 | |
microcontroller pic16f877a | Homework Help | 1 | ||
T | ARDUINO CODE TO PIC16F877A CODE | Microcontrollers | 1 | |
A | variable delay in PIC16F877A | Microcontrollers | 5 | |
Hx711 interfacing with PIC16F877A | Microcontrollers | 2 |
by Jake Hertz
by Jake Hertz
by Jake Hertz
