How to use optocoupler
SSR
Joined Aug 6, 2011
10
Hi all,
I need to use an optocoupler as a switch in my project instead of a relay, just for experiment if it work. The information on internet is too confusing. Just to mention i have used a relay and a transistor both separately as a switch.
Ok so and 6 pin optocoupler (e.g 4n35) has 3 input pins. We use 2 of them to power up the led and leave the third unconnected When the LED lights up it is detected by the photo transistor. The output also has 3 pins, we use collector and emitter and leave the base unconnected. When the photo transistor detects an IR light, does it shorts the collector and emitter so that what ever is on emitter is available on collector or vice versa?
Thanks.
MaxHeadRoom
Joined Jul 18, 2013
28,688
Essentially yes, you have the option of leaving the base open, and the transistor output turns on from the LED, and you can use either side as the output.
Usually depends on whether you need to sink or source the data.
Max.
