how to use MCP 601 in current to voltage converter mode
Discussion in 'General Electronics Chat' started by ranjini.np, Apr 10, 2008.
  1. ranjini.np
    Apr 10, 2008
    hello all,
    good afternoon
    i wanted to use MCP 601 in current to voltage converter mode
    here input current can be maximum upto 2A
    please guide me to clear this issue
    Regards
    Ranjini
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Use a very small value resistor in series with your current. Use the OpAmp to measure the voltage across that current sensing resistor. Select OpAmp feedback for the volts-per-ampere ratio you need.
  3. nomurphy
    Aug 8, 2005
    567
    12
    See figure 3-9 in attached, as an example.
  4. Pich
    Mar 11, 2008
    119
    Do you want to read the current or build a current source?
  5. haran
    Apr 6, 2008
    42
    can u brief me on the MCP 601 is it a standard regulator?
