how to use Hall Effect
Discussion in 'General Electronics Chat' started by mikelynch, Jan 9, 2011.
  1. mikelynch
    Jun 30, 2007
    23
    hi,
    I want to use hall effect on bike wheel but not sure how to use it. Is a 10k resistor between 5+ and output all that is needed ? (pins 1 and 3)
    will it toggle to ground/zero while connected to 5+ ?
    this blurb was on the site which has the sensor:
    Posted by Marcwolf on 15th Jun 2010
    Bit of an application note for the unwary
    Looking from the front where the writing is
    Pins run from left to right 1,2,3
    Pin 1 is +5v (or +3.3v)
    Pin 2 is Gnd
    Pin 3 is Output
    Put a 10K resistor between pins 1 & 3. The output will then toggle between High and Low with the magnet. Upi can feed that directly onto a digital pin of a PicAxe or Arduino }}
    http://www.sparkfun.com/datasheets/Components/General/Hall-US1881EUA.pdf[​IMG]
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    That would be the one I'd use first.
  3. mikelynch
    Jun 30, 2007
    23
    do you mean a resistor between Vdd and Grnd ? what value for a 5 volt circuit and a 10k bnetween vdd and output.
    thanks.
  4. Kermit2
    Feb 5, 2010
    3,852
    968
    I see two resistors. What are you looking at that has just one resistor?
  5. Kermit2
    Feb 5, 2010
    3,852
    968
    According to the data sheet for 5 volts it was 3.6 mA min.? I think. <snip> now that I've closed the pdf and blinked a few times, I can't remember.
    Use the value in data sheet, a calculator and the formula.
