How to use an IR receiver and IR remote control without an Arduino?
ElectroBoy7
Joined Dec 22, 2015
33
Hello everyone!
I've been looking for information about the topic above and I haven't found nothing and I keep wondering how to do so and this is the project I have in mind:
I want to place a Stepper Motor close to my light's switch and create a circuit with an IR receiver and an IR remote control so when I press a button in the Remote control, the stepper motor rotates a determinate number of degrees to turn on the light and when I press another button it rotates a determinate number of degrees in the other direction to turn off the light. I know this is quite easy to achieve with an Arduino but can I do it with a circuit without using a IC?
Thanks in advance!
AnalogKid
Joined Aug 1, 2013
11,056
ebay has remote controlled light switches, usually RF based. Or do you really want to build something from scratch? If so, them it will take a little circuitry, and a small power source to run it. Also, two buttons means a way to decode which one has been pressed, a more complex task than a single button that initiates a self-reversing system.
ak
mcgyvr
Joined Oct 15, 2009
5,394
Why complicate it with a stepper motor? (adding complexity for stepper driver, precise number of steps, mechanical linkages,etc..)
Just get a remote controlled relay and splice the hot lead of the lamp into its contacts.. Or make a box that the lamp simply plugs right into if you don't want to splice into anything..
ElectroBoy7
Joined Dec 22, 2015
33
Thanks for your reply! Do you mean this: http://www.instructables.com/id/Remote-controlled-relay/ ?
This would be easier, and if you study the schematics (free online) you will see exactly how to make an IR remote without an arduino.
http://www.amazon.com/Velleman-MK16...1&redirect=true&ref_=oh_aui_search_detailpage
That's a really good piece of info! Thanks a lot :D
