How to use a regular scope in place of the "PC Scope"
Discussion in 'General Electronics Chat' started by rlinnabaryjr1, Apr 28, 2014.
  1. rlinnabaryjr1
    Oct 25, 2013
    I have a silly question that I would hope someone could answer for me, how do you hook up a regular scope to the keyboard instead of a PC? It don't look to me like you can do much with the PC version hooked up...
  2. #12
    Nov 30, 2010
    16,664
    7,311
    You're going to have to describe a lot more than that. My scope doesn't connect to a keyboard in any reasonable way.:confused:
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    To the OP, think make / model of oscope. My scope is pure analog, no interfaces at all. That is what I think of as a oscope is.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Some scope allow being remote controlled from a computer and also data transfer. But hooked up just to a keyboard. Never seen that
  5. PRS
    Aug 24, 2008
    989
    35
    Be careful when you hook the scope up that the computer's ground is either floating or true ground. If the power cord has a third prong check the continuity between that and the circuit ground. I once assumed a TV chassis was ground and hooked my oscilloscope ground, which was true ground, to it and shorted it out. I've been careful ever since.
