How to use a 12V input and 240-24V Relay switch to run a DC 12V motor with Aurdino
Discussion in 'General Electronics Chat' started by rahulsharma255415, Jan 13, 2016.
  1. rahulsharma255415
    Jan 13, 2016
    I have a set of 4 240 to 24 V AC or 120-24 V DC relay.(mentioned on top) input it takes is 5 V from aurdino. I have a 12 V DC motor. How do I use this relay switch to run this 12 V DC motor. I have programmed my aurdino to work with relay and run the motor. The LEDs with the relay show the timing. I am confused how to run my 12V DC motor using the 24V relay
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    The 24v of the relay is just for the coil, the output terminal are for what ever you want to switch with them, IOW use a N.O. contact on the output terminals to switch 12v to your motor.
    I presume you have some detailed information on the board itself??
    Max.
