how to turn on a power supply
Discussion in 'General Electronics Chat' started by jonisonvespa, Apr 5, 2012.
  1. jonisonvespa
    Mar 25, 2012
    49
    hi
    im currently learning to program ardunio and for my project im using a 5v regulated power supply, and id like to turn on/off this supply to everything using a momentary push switch, been searching for circuits to do this , cant really find one can someone point me in the right direction, ie what this type of circuit is called.
    thank you
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    try a latching pushbutton. push once, makes the circuit, push again, breaks the circuit. put it on the +5V going to the arduino.
  3. debjit625
    Apr 17, 2010
    790
    186
    An electronic latch switch,this type of circuit is called bistable multivibrator in electronic or in digital electronic Flip-Flop circuit.Their are many flip-flop digital IC avaliable you can use them to built an electronic latch switch.
    Good Luck
  4. KMoffett
    Dec 19, 2007
    2,584
    234
  5. jonisonvespa
    Mar 25, 2012
    49
    found what i was looking for
    thank you
