How To turn Dc to Ac
Discussion in 'General Electronics Chat' started by szymonm2, Jan 26, 2016.
  1. szymonm2
    Jan 26, 2016
    17
    Hello.
    Im trying to find an answer to my problem for the past couple of weeks but I cannot seem to find it.
    How do I turn an output of 0-30V DC (10A) into 0-30V Ac?
    All circuits that I found changed to voltage to either 110v/ 230v...
  2. Lestraveled
    May 19, 2014
    1,957
    1,217
    Could you be a little more specific. What frequency and waveform? Also some application information would be good.
  3. szymonm2
    Jan 26, 2016
    17
    I want to power up ac devices such as ac motors. 50hz or 60hz would be good i suppose. I dont have such deep knowledge in alternating current.
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
  5. Lestraveled
    May 19, 2014
    1,957
    1,217
    Are you getting the DC voltage from batteries?
  6. szymonm2
    Jan 26, 2016
    17
    No. Im getting power from a lab bemch psu 0-30v 10a
  7. Lestraveled
    May 19, 2014
    1,957
    1,217
    Why not just use a step down transformer off of the mains? Is this school homework?
  8. spinnaker
    Oct 29, 2009
    5,065
    1,164
    Then I assume you already have AC available. Why would you want to convert DC to AC?
  9. Dodgydave
    Jun 22, 2012
    5,142
    768
    If the bench psu is yours, you could use the transformer outputs to give you 30V AC, you would need to measure its output and put a couple of yellow 4mm sockets on it. If you want variable ac your better using a variac transformer , otherwise its an inverter.
  10. mcgyvr
    Oct 15, 2009
    4,787
    973
    Post detailed information on the motors and other AC loads you intend to power..
    part numbers would be great.. or motor nameplate ratings..
    As stated a transformer off the mains may be a better solution than an inventer and may be the only way based on details of the AC loads/motors..
  11. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Which motors do you have with a 30VAC rating?
  12. Kermit2
    Feb 5, 2010
    3,847
    963
    I just happened to have a rather chunky stepdown xformer of 800 VA capacity. 480 to 120 single phase.
    I used it with a variac to get a 0 to 30 volt AC out with 120 AC input.
    It was convenient for testing the two universal motors I scavenged out of old vacuum cleaners. Full voltage on them without a significant load means possible runaway self destruction.
    And they would really spin with 12 volts DC input from a lead acid battery
  13. Kermit2
    Feb 5, 2010
    3,847
    963
  14. szymonm2
    Jan 26, 2016
    17
    Thr power supply is a switching one and i cant do that... i am using a 12v 20amp psu that is connected to a buck boost converter (ltc3780 to be exact). So kermit2' s schematic would work for sure?
  15. spinnaker
    Oct 29, 2009
    5,065
    1,164
    You never answered the questions. If you have AC available, why not just use a transformer?
  16. szymonm2
    Jan 26, 2016
    17
    Because I cant desolder my current transformer from the pcb??????????
  17. Dodgydave
    Jun 22, 2012
    5,142
    768
    Ok, does it have to be variable AC, or would a fixed voltage work ?
  18. szymonm2
    Jan 26, 2016
    17
    I was hoping that you could make a variable dc-ac circuit?
    My power supply already has a variable 0-30V Dc range? Would that help in any way?
  19. Dodgydave
    Jun 22, 2012
    5,142
    768
    You said your psu is a switchmode type, it will alter the pwm to give a variable voltage, unless you're wanting to make an inverter which to me is a waste, use a small transformer to drop the mains 120V or 230V to 30V to test the motors, or if you want a variable AC supply use a variac.
  20. szymonm2
    Jan 26, 2016
    17
    I have a switch mode power supply attached to a buck/boost converter which in return gives me a range between 0-30v 10a. Im basically looking for a circuit that enables me to change Dc to Ac without a voltage change....
