How to turn D Latch to D Flip-flop?
Discussion in 'Homework Help' started by TheRiverRamones, May 5, 2008.
  1. TheRiverRamones
    May 5, 2008
    My problem is to implement a solution that changes D latch to D Flip-Flop, using simple logic, and present the circuit that comes with this solution. Can you help me?
    PS: If it's not the right place, move it, i'm new in the forum.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A latch is simply an enable signal and a D input. A flip-flop adds SET and RESET inputs, and so becomes more complex.
    Have you got the logic for the latch function yet?
  3. mik3
    Feb 4, 2008
    4,846
    63
    on the clock input of the D latch place an AND gate with two inputs (say A nad B). Connect A to three NOT gates in series and then connect the input of the last NOT gate in the tail to B. use B as your clock input. This is for a positive edge. For a negative edge replace the AND gate with a NOR.
  4. Caveman
    Apr 15, 2008
    471
    Technically, SET and RESET inputs are not required for a flip-flop. They are just typically there.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Ok, probably not necessary. I was just looking at the internal logic for a 74LS75 and a 74LS74.
