How to trigger a 5 sec delay without using 555 ic
Discussion in 'General Electronics Chat' started by tpny, Oct 15, 2012.
  1. tpny
    May 6, 2012
    216
    I want a pushbutton when pressed and released to trigger a 5 second (or x seconds whatever) voltage level change (high to low or low to high doesn't matter) without using a timer ic. Any guidelines? Thanks!
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    You can use a relay timed by a charged capacitor or in place of relay you can use transistor..
  3. tpny
    May 6, 2012
    216
    Yes, I knew I had to have a cap in there, just didn't know how to put it in a circuit to serve this purpose. Do you have a drawing? Thanks!!
  4. crutschow
    Mar 14, 2008
    13,488
    3,372
    What voltage(s) do you have for power?
  5. tpny
    May 6, 2012
    216
    between 14~16Vdc
  6. KJ6EAD
    Apr 30, 2011
    1,426
    363
    You might be able to use a three inverter oscillator and a counter.
  7. ScottWang
    Aug 23, 2012
    4,926
    777
    You can use two NPN transistors connect them similar as darlington, but the each C of two NPN connecting a 10K to +V.
    The circuit as this:
    +V → Start Key → 1K → Cap([-] toGND) [+] → 1M Ω → two BJT → C output of second NPN.
    The similar as darlington driver on the top of right side of page 2.
    Take off the Rbe,Re resistors from the first NPN Tr1.
    http://panasonic-denko.co.jp/ac/e_d.../common/catalog/mech_eng_cau_appli.pdf?via=ok
  8. crutschow
    Mar 14, 2008
    13,488
    3,372
    You could use a single MOSFET which has the advantage of a very high input impedance, allowing a larger value of resistance and a smaller value of capacitance then a BJT.
    The circuit would be +V\rightarrowStart Key\rightarrowcapacitor\rightarrowMOSFET gate & resistor with resistor\rightarrowground. Connect the MOSFET source to ground and the drain through a resistor to +V (resistor value determined by load). This will cause the MOSFET drain output to go momentarily low and then back high when the Start Key is pressed. Try R = 10MΩ and C = 0.5μF to start.
    To reset the capacitor you will need to add a resistor, 1MΩ or less, from the switch output to ground.
  9. Dodgydave
    Jun 22, 2012
    5,150
    769
    The relay will operate immediately the push switch is pressed, and stay operated until the capacitor discharges,time depends on coil resistance and capacitor value, bigger values = longer time delay.
