I want to separate a LCD touch screen from a tablet and transmit the data from the pin out for the digitizer and screen in between the main board and the now remote screen. I would be interested in going so far as to making a separate board and removing the Digitizer IC and Display interface from the main board to transmit a more easier to understand signal type. At first I was trying to figure out how to send the information over a master/slave bluetooth connection but was told that the mega bytes per second may not be large enough to handle the information. I have since thought about going with a AV transmitter and receiver. But I don't know if the digitizer data would be able to be used like audio.
A unit kind of like this
https://www.maximintegrated.com/en/app-notes/index.mvp/id/3578
I also though about going with a couple of these units one for each direction
https://www.aliexpress.com/store/pr...tting-TX-TS5828-for-5/727847_32378907248.html
If anyone could enlighten me on the feasibility of this that would be great. I have considered purchasing electronic gear to diagnose what types of signals I would be working with but anywhere else I have asked has stated that I would need an electronic engineering degree to try and figure this out.
