How to transit between main and battery power
Discussion in 'The Projects Forum' started by witssq, Apr 8, 2012.
  1. witssq
    Thread Starter Active Member
    Mar 29, 2009
    48
    Please advise how to transit from main power(3.3VDC) to battery power when main power on, vice versa. as computer does.
    I would like to rtc clock such as personal computer.
    Thanking you in advance.
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    Use a Schottky diode such as 1N5817 between the main power and the battery powered circuit.
  3. panic mode
    Oct 10, 2011
    1,328
    305
    you mean switch from main to battery power when main power is off
    why would you want to run on battery when main power is present. ;)
