Hello all,
I'm trying to build my own H bridge, not wanting to start using an already made motor controller from the beginning. I've seen a lot of designs online, but there's no deciding which is better. Plus, most of those designs were not made for my desired voltage.
I will be using a 6V motor from a toy car. I don't know how much current it draws, but I'm guessing somewhere around 300mA tops. It's not a powerful motor. I would like a design that allows the motor as much power as possible, so basically something that will drop as little voltage as possible and won't dissipate much power.
From what I've read, using two N MOSFETs and two P MOSFETs as well as two NPNs works best. But I've also read that for this design to deliver the necessary current to the motor, the MOSFETs need to be above a certain voltage (Vgs?). Judging by some of the datasheets, that's not really happening at 6 volts.
Then there's the fact I'm not sure how to pair the N and P MOSFETs in the design if they DID work at 6 volts. Do they have to be rated for the same voltage or amperage? How do I choose them from the catalogue?
I hope that was somewhat coherent and I'm waiting for some answers
