How to test transitor is functioning
Discussion in 'General Electronics Chat' started by eggtree, Nov 28, 2006.
  1. eggtree
    Nov 28, 2006
    27
    How to test transitor is functioning as a switch?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    In circuit, look at the collector voltage. Assuming it's set up as a grounded emitter, the collector voltage should be about the same as Vcc when off, and should be at ground potential when on.
    Out of circuit, use a meter to see if the p-n junctions B to E and B to C are good, plus confirm that there is no conduction E to C.
  3. eggtree
    Nov 28, 2006
    27
    Thanks for your quick response.
