How to test the HT12E/HT12D & Tx/Rx 433 MHz RF Module
praondevou
Joined Jul 9, 2011
2,942
Ok, so you say the data outputs of the HT12D are correct, right.
In your schematic there is one big arrow showing the connection from HT12D to the development board.
Did you connect it correctly, can you post the link to the development board etc.?
If you want other people to respond you will need to give a good, detailed description of the problem.
mkbutan
Joined Sep 30, 2008
299
yes its as follows
IC 2 => Development Board
HT12D => μc (P89v51RD2)
pin 10 => pin 01/port P1.0
pin 11 => pin 02/port P1.1
pin 12 => pin 03/port P1.2
pin 13 => pin 04/port P1.3
__________
the LCD shows "EFY
Water Level LOW,25%,100%(50%,75% not working (have to check the Tr. BC547, that today i will replace it with the new one's))
__________
sir,
the program D/L from the site is in *.asm/*.lst/*.hex can the same code's can be written in "C" language as i am learning this language.
__________
and the same ckt. can be used to operate the pump, with some add. modification with the help of RELAY's
mkbutan
Joined Sep 30, 2008
299
hi
finely the ckt is working
now can any body guide how to upgrade it with auto ON/OFF
there are still 4 ports ideal (P1.4;1.5;1.6;1.7)
