Please kindly through light on my following.
1. Is all LED same ie AC and DC?
2. If LED for AC and DC different, then how Do I know if it is AC or DC LED?
3. I have collected the light indicator(small bulb) from rice cooker/water boiled.
a) what do we call this type of light bulb, LED or ????
b) I tested for bad or good, with ohm meter, Continue mode and diode
mode,( set in auto mode)but no showing and reading.It remains 0L. Then i
have tested the bulb putting with AC source of 240 Volt using 120k. then
then it is fine (glowing)
C) How do we test this type of light indicating bulb? how do we test it using multimeter?
Apology: With regard to my question No. 3 a) above. I remembered now that one of senior members told me it is called neon bulb in one of my prviouse post. So no need to explain on Q. 3 a))
Thank u
Thank you
Thank u
Thank you
