The program current is set by the resistance between the Vout and Vadj terminals. It is designed to be a stable reference/current.I see... So, how does the LM317T avoid the Ouroboros effect resulting in exponential change? What's fed into ADJ affects Vout which is then changed by R1 & R2 and fed back into ADJ.
There is no feedback from changes in the value of R2 as long as Vout stays within the range required for the regulator to function. What the regulator is doing is maintaining a constant 1.25V between Vout and Vadj.
Did Mouser offer datasheets from multiple manufacturers? I prefer to use the one from National Semiconductor. It always contained more information than datasheets from other manufacturers. A quarter of TI's version is dedicated to package information. You can get the Nat Semi version here.Where'd you get that schematic from? I can't find it in the one I have from Mouser.
If you choose a resistor that will give a program current of 10mA, the effect of Iadj (100uA max) can be neglected because it can be compensated for by the pot and the effect of Delta Iadj (5uA max) will be insignificant (5uA*1kΩ = 5mV).Why can I ignore the effect? "Delta Iadj"?
There is only one Vout. The "second" one shows where circuit ground and the output are taken.What's with that second Vout after R2 in your schematic? Am I supposed to join the two Vouts?
