It's a "10K POT", but I measured the resistance to be 11.56KΩ to 2.5ΩI cannot make out the POT value from the diagram.
How did you get to that? Sorry, still learning to make sense of datasheets and how to use the information.Data says 5K.
What's resolution?That's fine, but my point was a 1K will give the OP better resolution because he has a 12V input voltage.
So, I should have used the Reference Voltage? Which would also be the minimum output voltage?R1 always has 1.249 volts across it. That is a constant for this chip.
