How to test a LM317T Voltage Regulator
Discussion in 'Power Electronics' started by Binary Buddha, Sep 24, 2016.
  1. Binary Buddha
    Sep 24, 2016
    30
    • I know nothing about electronics except how to put batteries in. I'm a total noob. Be gentle. I'm here to learn.
    • Why? I heard a rumor about counterfeits and that they should be tested. I just need a simple test to verify it's doing what it's supposed to be doing.
    • I'm armed with Eagle CAD and I don't know how to properly use it.
    • Yes, I've read the datasheets. But, my lack of knowledge and understanding the basics keep me comprehending it. It's like reading Klingon. http://www.mouser.com/ds/2/389/lm217-974117.pdf
    So, I'm trying to figure out a simple test to see if the all the regulators I got in are counterfeit or not. Would the below diagram be a suitable test? I'm assuming I set my multimeter to DCV with the red probe on VOUT and the black probe on GND.
  2. crutschow
    Mar 14, 2008
    13,488
    3,372
    That would tell if it's basically working.
    The output should be about 1.25V with 1.25A through the 1Ω load.
    You only want to do that test for a second or two without a heatsink since the device will be dissipating about 7.75W.
    If you want to test whether the voltage is adjustable you would need to add a pot and resistor to the circuit, along with a higher resistance load resistor.
    Note that your 9V source has to supply 1.25A to test the posted circuit.
    atferrari and Binary Buddha like this.
  3. Binary Buddha
    Sep 24, 2016
    30
    Thanks for responding!
    I couldn't find a 1Ω so I used a 560Ω and got 1.249V. Is that about right? As for the power, it's a 9V battery at 0.83mA... I'm guessing adding a second 9V battery wouldn't work.
  4. #12
    Nov 30, 2010
    16,676
    7,320
    1.249V is within specs.
    Your little 9V batteries aren't strong enough to test the limits of a good LM regulator chip.
    If you want to push the limits, you will need more than a couple of amps.
    What you tested was the reference voltage. There is a lot more to learn about self-limiting current operation, safe area of operation limits, transient response speed, regulation under load, etc.
    John Berry likes this.
  5. Binary Buddha
    Sep 24, 2016
    30
    I know. It's the whole reason I'm here. Would one of those 12V square flashlight batteries do the trick?
    Part of the reason I need a working regulator is to build this.
    http://www.instructables.com/id/Variable-ATX-bench-powersupply-FabLab-edition/
    With that, getting proper amps and voltage for supply won't be much of an issue. ... At least I hope so...
  6. Binary Buddha
    Sep 24, 2016
    30
    Is this right? Should result in about 11.946V
  7. R!f@@
    Apr 2, 2009
    8,789
    771
    Adj pin should not be grounded.
    Check the datasheet for proper diagram
  8. #12
    Nov 30, 2010
    16,676
    7,320
    Yes. Those massive cubes should be able to throw 10 amps for a little while, and an amp, all day.
    Use 120 ohms for R1 to satisfy the minimum load of 10 ma.
    Change R2 to fit the 12V requirement. 1033 ohms is the calculated value.
  9. Binary Buddha
    Sep 24, 2016
    30
    Can you clarify? I'm apparently not interpreting the datasheet correctly. Another forum said that VOUT is the regulated voltage. If that's true, then what does ADJ connect to? In this diagram from the datasheet, I thought that thick black line under R2 meant ground.
  10. #12
    Nov 30, 2010
    16,676
    7,320
    The black line under R2 does mean ground, but that doesn't mean attach the adjustment pin to ground. Your drawing in post #9 looks good.
  11. Sinus23
    Member
    Sep 7, 2013
    178
    465
    The black line does indeed...
    #12 beat me to it:D
    But in post #6 the adj was shorted straight to the ground
  12. Binary Buddha
    Sep 24, 2016
    30
    120Ω or 1200Ω? R=V/I = 12/0.01=1200 ... No?
    Change R2 to fit the 12V requirement? I'm assuming I use Io(max) on the datasheet, but not sure which number to use where since it's a potentiometer. 1033Ω for R2? I=V/R = 12/1033=~12ma ... kind of confused...
  13. Binary Buddha
    Sep 24, 2016
    30
    So what does the wiper pin on the POT connect to? POT pin 1 is input from R1... POT pin 3 is GND... POT pin 2????
  14. R!f@@
    Apr 2, 2009
    8,789
    771
    The pot needs to be around 5KΩ
    I cannot make out the POT value from the diagram.
    And connect pin 1 and pin 2 of pot together .
    The POT can be varied to adjust the output to your desired voltage
  15. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    It's good that you're aware of the issue with counterfeit parts, but testing is probably beyond the capabilities of most hobbyists.
    Basically you'd need to test all of the parameters that the manufacturers check and it's unlikely you'll have the appropriate equipment. In addition to reference accuracy, you'd need to check: max current, thermal protection, load regulation, line regulation, ripple rejection, drift, ....
    If you're determined to do this, you'll need to build some test circuits and have an oscilloscope.
  16. dl324
    Mar 30, 2015
    3,377
    651
    The pot should be 1K. The output voltage can only be adjusted to around 9-10V and 1K will give a 10V adjust range.
  17. dl324
    Mar 30, 2015
    3,377
    651
    As mentioned, connect terminals 1 and 2 together. That will give you increasing voltage with clockwise rotation.
    Also, learn style from other (well drawn) schematics you see. Current flow should be primarily from left to right and top to bottom. Wires should be drawn using multiples of 90 degrees; with the exception of wires entering/leaving buses.
  18. R!f@@
    Apr 2, 2009
    8,789
    771
    I use 5K.
    I can adjust from 1.25V to 20V with a 24V input.
    Data says 5K.
  19. dl324
    Mar 30, 2015
    3,377
    651
    That's fine, but my point was a 1K will give the OP better resolution because he has a 12V input voltage.
    And, since he is learning, he should learn how to select appropriate component values.
    R!f@@ likes this.
  20. #12
    Nov 30, 2010
    16,676
    7,320
    R1 always has 1.249 volts across it. That is a constant for this chip.
