How to test a high voltage diode
Discussion in 'General Electronics Chat' started by Gdrumm, Oct 29, 2011.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    A Google search method says to hook up one end of 110v to the cathod end of the diode, then hook the other end of the diode to the neg probe of your meter.
    Next, hook the other side of the 110v to the pos probe of the meter, set the meter to 200v ac and turn on the power.
    The Meter should read 1/2 of sine wave, or about 55 to 60v = good...
    Anything else, any different readings = bad
    I've tested about 10 of my HV diodes, and all are showing from 119 up to 125v ac one way (supposedly bad). and when reversed, they show 0 volts. To me they are doing what a diode should do. Let current flow one way...
    Is there a better way to test these HV diodes?
    Thanks,
    Gary
  2. praondevou
    Jul 9, 2011
    2,936
    489
    THIS looks more like a suitable test setup.
    In the setup you described (connected to110VAC), why would inverting the diode give a different result ? Can you post the link you got this information from?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    While the fellow in that video is using an acceptably low voltage range, he's getting some rather odd results. I agree that if the diode is reverse-biased, you should measure about the same as the supply voltage across the diode. However, if the diode is forward-biased, you should read a rather low voltage (0.7v-1v) across the diode - unless they are REALLY high voltage diodes.
  4. praondevou
    Jul 9, 2011
    2,936
    489
    Yep, we would need to know the model # to compare the obtained Vfd @ the applied current with the informations in the datasheet. I don't know what "HV" means in terms of max reverse voltage......
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    "Stack" rectifiers are quite common for higher voltage rectification, at kilovolts upwards. Here the manufacturer assembles a number of matched junctions in series stacks, somewhat along the lines of the old metal rectifiers. Some high voltage rectifiers are still made this way using selenium, but most are now silicon. A much higher PIV is possible than with a single junction, at the cost of a larger forward drop.
    Example of HV rectifiers with larger forward drops: http://www.ppmpower.co.uk/downloads/products/page04.pdf
    If I had any doubts about the health of such a device, after basic testing I would be inclined to carry out a reverse leakage test at voltages approaching its full rating. Such testing cannot really be advised on here, but I would point out that at any voltage, leakage testing must not be done simply with diode and ammeter in series across the supply - if the diode fails excessive current will blow up the meter. Use a resistor capable of withstanding the full voltage in series with the diode
    praondevou likes this.
  6. debe
    Sep 21, 2010
    955
    185
    When checing Microwave oven diodes I use a Megger tester on 1000V to test them as a multimeter wont work on them.
  7. debe
    Sep 21, 2010
    955
    185
    Heres how i do it.
  8. sheldons
    Oct 26, 2011
    616
    101
    Heres the schematic for my high voltage diode tester-which can also test capacitors(mw caps and mw diodes and asm rectifiers) ive been using it for years.....it also checks leds too
