How to temporarily fasten pin headers before soldering?
Discussion in 'General Electronics Chat' started by JimG, Jun 6, 2010.
  1. JimG
    Dec 7, 2009
    53
    I use a lot of pin headers or Molex pin connectors on my PCB's and am constantly struggling to find a good way to temporarily hold them in place, upside down, while soldering.
    I've used SuperGlue with varying amounts of success (mostly less success).
    The problem, of course, is that the pin headers like to fall out when I flip the board over.
    How have others overcome this problem?
    Jim
  2. retched
    Dec 5, 2009
    5,201
    313
    I use a piece of component foam, stick it on the tops of the headers then secure the foam to the PCB with standard tape.
  3. JimG
    Dec 7, 2009
    53
    No problem with the foam overheating or melting?
    Thanks.
    Jim
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    Masking tape (actually drafting tape) but it doesn't work perfectly. I have thought about a drop of hot glue; it would work well but it's some trouble to use.
  5. JimG
    Dec 7, 2009
    53
    Yeah, I've been thinking about the hot glue approach, too. I've got to find something because burning my fingers on the tips of the pins is getting old.
    Jim
  6. Razor Concepts
    Oct 7, 2008
    212
    Stick the pins in loosely (doesen't matter if crooked), solder one pin to tack it in place. Re-orient the PCB, while holding the pins from the non-tacked end, re-heat the tack and push the pins to get them to be straight. Solder the rest of the pins. (only really works well for 3+ pins in a row)
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I have a piece of board stock I lay over the MTA headers I use. I can hold the cover over the headers and invert everything so the headers stay in place. Things do wiggle, so I use the above method of tacking one pin. A metal handle of some loose pliers makes the ideal surface to apply pressure with to straighten the headers one at a time (with the PCB upside down, I can press one at a time onto the handle).
  8. retched
    Dec 5, 2009
    5,201
    313
    The first time, the headers will cook little cups into the foam. you gotta be quick.
  9. KMoffett
    Dec 19, 2007
    2,584
    234
  10. JimG
    Dec 7, 2009
    53
    That looks like a winner, too. Haven't seen that stuff since the kids were out of grade school! But as I recall it can be used to stick anything to anything else :)
    I've got some boards on the way (soon, hopefully) from BatchPCB. I've got some good new options to try for soldering the pins.
    Thanks to all who responded.
    Jim
  11. kingdano
    Member
    Apr 14, 2010
    377
    19
    i have always used foam at work...or a pair of tweezers...or cardboard...:D...but seeing the bluestik seems like a great idea.
    thanks for the idea
