How to tell if EN28J60 is connected to the router
Discussion in 'Embedded Systems and Microcontrollers' started by yogesh1990, Feb 5, 2012.
  1. yogesh1990
    Oct 5, 2010
    11
    Hi.. people ... I m implementing an embeded web server using ENC28J60 and PIC18F4550
    I implemented the TCP/IP Stack and burned the hex file onto the uC .. How do you tell if your ENC is connected to the router ...
    I connected ENC physically to the netgear router using a CAT5E but router did not glow the LED saying a device was connected to ethernet port ?..
    Is there something that I'm missing ?
    Nor does there is any response from ping requests (I have an ICMP server )
  2. cheezewizz
    Apr 16, 2009
    82
    10
    Your router should maintain a list of currently connected (and sometimes previously connected) devices. You can normally access this through the web UI for the router, i.e. pointing a we browswer at 192.168.0.254 or whatever the IP of your router.
  3. yogesh1990
    Oct 5, 2010
    11
    Yea.. I can't see it in the list of attached devices page on the router ... Does the ENC need prior programming to even get the router connected to it ?
