How to tell capacitance of small capacitors by the numbers on them?
Discussion in 'General Electronics Chat' started by Yaşar Arabacı, Nov 19, 2014.
  1. Yaşar Arabacı
    Nov 11, 2014
    32
    Today I went to the electronics store and bought some capacitors (well, I hope that is actually what I got :) ). Anyways, bigger ones have capacitance values written on them, but smaller ones only have some numbers like 103, 104 etc. Shop owner said that I could tell the capacitance from those numbers, but I don't really know how to do that.
    Is there something like a datasheet that will tell me the capacitance from the values written on capacitors?
  2. ISB123
    May 21, 2014
    1,240
    531
    Those are capacitor codes.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    Caps like that are indicated in picofarads. Your 103 is 10,000 pf or .01uf and the 104 is 100,000 pf or .1uf. First two positions are value and last position is multiplier or how many zeros follow the first two numbers. Example 105 is 1uf and 475 is 4.7uf.
    alfacliff likes this.
  4. wayneh
    Sep 9, 2010
    12,368
    3,224
    That's the one fact to remember - picofarads. Then the printed digits are a lot like the 3-band resistor color code; two significant digits and a multiplier.
  5. BobTPH
    Jun 5, 2013
    806
    121
    And if there are only 2 digits, it is just that value in picofarads. I.e. a 47pF cap will usually be labeled 47 instead of 470 and both would designate the same value.
    Bob
