How to switch the ac phase not the neutral
Discussion in 'The Projects Forum' started by Mostafa Elhabrok, Nov 5, 2015.
  1. Mostafa Elhabrok
    Nov 5, 2015
    11
    i have a single phase ac motor, and i have 3 apartments each one uses a different phase.
    i want to run this motor from every apartment by standard switch.
    the problem if two switches are closed at the same time, i have two phases shorten .
    i wanted to use a triac but i realized that it controls the neutral side (because of the common ground and using the gate )
    i want to control the PHASE side of each phase of the three.
  2. BR-549
    Sep 22, 2013
    2,181
    419
    “i want to run this motor from every apartment by standard switch.”
    Do you need to ONLY activate the motor from each apartment by chance?.......just turn on?
    Or do you need complete, separate control from each apartment?
  3. Alec_t
    Sep 17, 2013
    5,973
    1,135
    The disadvantage of using a triac (or SSR with a triac output stage) is that it can fail either open circuit or short circuit. If the latter, then you could have two phases shorted. Can you arrange to power the motor from only one phase, but use the switches just to provide input signals to a controller for the motor?
  4. recklessrog
    Member
    May 23, 2013
    346
    102
    I would be safer to use relays as there is less chance of them failing short circuit like semiconductors can. All you need then is to have a simple Phase monitor control that senses whether there is power to the motor and will not allow another phase to be turned on until the others are off.
    We controlled 4.5kV 6 phase windings on massive motors like that back in the late 60's early 70's.
  5. Mostafa Elhabrok
    Nov 5, 2015
    11
    every apartment has its switch, what i need is that every apartment is able to run the motor from its phase without two phases shorten.
    as if two switches are closed at the same time that will be a short circuit between different phases
  6. Mostafa Elhabrok
    Nov 5, 2015
    11
    that is a good idea but i did not prefer relays as they are slower , and depend on mechanical parts
  7. BR-549
    Sep 22, 2013
    2,181
    419
    What is the motor doing for these apartments?
  8. Mostafa Elhabrok
    Nov 5, 2015
    11
    the problem is that the motor is running alot , and every apartment its own power meter ( cost )
  9. Mostafa Elhabrok
    Nov 5, 2015
    11
    it is a water motor (pump)
  10. BR-549
    Sep 22, 2013
    2,181
    419
    What prevents apartment #1 and apartment #3 from drawing water, when apartment #2 has the pump on?
  11. Mostafa Elhabrok
    Nov 5, 2015
    11
    the pump provides water for the three whatever any apartment turned it on
  12. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    If you want each apartment to pay their individual cost, what happens if the demand is from 2 or 3 apartments and the same motor is used?
    Max.
  13. Mostafa Elhabrok
    Nov 5, 2015
    11
    if there is any way to control which phase is connected to the motor
    sorry i do not understand what do you mean
  14. Mostafa Elhabrok
    Nov 5, 2015
    11
    i appreciate everyone's help
    but on my condition is there any digital way to control the 3 phases as the following
    when
    apartment #1 closes its switch then its phase is connected to the motor while the other two phases are disconnected
    and #2 and #3 like the same
  15. BR-549
    Sep 22, 2013
    2,181
    419
    So, whoever has the switch on......pays for everyone's water.
    I don't think I can help on this one.
    Mostafa Elhabrok likes this.
  16. Mostafa Elhabrok
    Nov 5, 2015
    11
    not like that whoever has the switch on his phase is only connected and he pays his (ELECTRICAL COST) NOT WATER COST
  17. BR-549
    Sep 22, 2013
    2,181
    419
    Watermeters.
  18. Mostafa Elhabrok
    Nov 5, 2015
    11
    no i dont care of this
    what i care is energy meter
  19. Mostafa Elhabrok
    Nov 5, 2015
    11
    when
  20. BR-549
    Sep 22, 2013
    2,181
    419
    Pump cost divided by the 3 water meters proportionally, is the only fair way, for your setup.
