How to switch between two potentiometers?
Discussion in 'General Electronics Chat' started by danforth, May 9, 2011.
  1. danforth
    May 8, 2011
    22
    Is this the correct way to switch between two potentiometers?
  2. ronv
    Nov 12, 2008
    3,401
    1,464
    Should work fine, but as you throw the switch there will be a short time when neither are connected to the circuit.
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
    The total resistance of the pots in parallel will now be lower than the resistance of the lowest. This may be a concern if the pots are fed from a resistor that would form a voltage divider.
  4. danforth
    May 8, 2011
    22
    Any idea on how to stop this from happening?
  5. kubeek
    Sep 20, 2005
    4,689
    806
    Use DPDT switch and switch 2 of the three wires, the ground should be left connected to both. If you can´t tell which one it is, try measuring resistance to power supply ground, or post a photo of the board.
