I have a transistor sr flip flop circuit that sets and resets an led. (Please see attached schematic.) At positions 's' and 'r' in circuit, if I each put a pushbutton switch tying the flip flop transistor's base to ground, I can press 's' to switch on the led and 'r' to switch off led.
I want to replace the pushbuttons by transistors. I need the transistors to perform that same sr operation so I think I need to make the transistors switch between ground and floating. How can I do that? Thanks for your help!
